Build Up Opinion
Old Jan 9, 2006 | 07:45 PM
nsn240's Avatar
VIniie... i think the t25 maxes out lower than the t28... closer to 14-15psi
Old Jan 9, 2006 | 10:59 PM
Waynehead05's Avatar
^ true... it'll blow HOT air at 18 psi.
Old Jan 10, 2006 | 05:27 PM
BigVinnie's Avatar
Re: Build Up Opinion
Originally posted by SeanC_wa
ok so i read the FAQ here and my goal is 350 WHP.
ok now would the t-series turbo be able to handle when i turn up the boost when i put the built long block in? say 20-25 psi
First question you stated that you wanted to make atleast 350BHP, so a T28 will do you just fine. The second question confused me when you stated that you wanted 20~25PSI (since making that much can make you atleast 480BHP or more dpending on trim and turbo.
Well after doing some research let me answer both questions as best as possible. The GT28 (garret) is offered in 3 trim sizes. I left the link at the bottom of the page.
A t28 can produce upto 440hp which is more than enough power that you wanted. I don't think you will generally need 20~25PSI.
http://www.performanceforums.com/for...php?t=67115502
Old Jan 10, 2006 | 05:30 PM
BigVinnie's Avatar
I'm going to look into that, but I believe they are the same since both (t25/t28 use the same housing). Spool time of the t25 is much more effecient on smaller displacement engines, doesn't mean it wont make the same PSI, and like you said it will be hotter when compressing that much air.
lrb_2000
Nov 23, 2004 10:27 AM
nflrican29
Feb 13, 2003 11:07 AM
wang6six6
Dec 13, 2002 01:46 PM
fliprayzin240sx
Northeast
Nov 30, 2002 09:45 AM
Catharsis
Feb 7, 2002 03:33 PM
