Crush washers for the turbo oil line
Old Mar 23, 2007 | 04:45 PM
Bumnah's Avatar
The line I'm talking about goes from the engine block to the turbo. I was able to source some crush washers for the coolant line, but I can't find any with the proper I.D. for the cursh washers around the banjo bolt.
ANyone point in the right direction?
Searching around the web I found this part:
turbo oil line o-rings - 15193-03E00
I'm not sure it's the right one.
Thanks in advance.
Old Mar 23, 2007 | 04:48 PM
from the block you will be utilizing and brass T. there is no crush ring involved
( this is the picture below without the rest of the 1/8 NPT fittings)
crush ring for the coolant banjo bolt can be found at your local car store, they carry assortment packs for about 5 bucks.
if you have advance auto on auto zone its in the help isle
Old Mar 23, 2007 | 04:56 PM
Bumnah's Avatar
I'm sorry. perhaps I wasn't clear. I'm not looking to redo my oem setup. I just want to replace my old crush washers with new ones for the oil line going to the turbo from the block .It's just a little lower than the line for the coolant. Coolant is all taken care of. THey look exactly the same, the oil bajo bolt just isn't as big as the coolant.
Are you suggesting I upgrade to that setup?
Old Mar 23, 2007 | 05:00 PM
hold up.... do you have an SR.....
Old Mar 23, 2007 | 07:15 PM
Bumnah's Avatar
yes. i have an sr.
Old Mar 23, 2007 | 07:19 PM
LOL yea i figured that... hmmmm yea you still should be able to get an assortment of crush rings..... or go to nissan.. they are just standard.
Old Mar 23, 2007 | 07:20 PM
Bumnah's Avatar
went to nissan. no dice... grrrrr. maybe hit up another dealership and see what happens.
Old Mar 23, 2007 | 07:22 PM
hmmmmmm... thats wired they usually have them just laying around with a bunch of standard bolts etc....
do you happen to have one of the old rings....
Old Mar 23, 2007 | 07:34 PM
Bumnah's Avatar
yup. took it with me.
tried car quest, napa, autozone, advance auto. none have a similar sized crush washer....
Old Mar 23, 2007 | 07:47 PM
are you totally against switching over to braided lines?
Old Mar 23, 2007 | 07:53 PM
I totally think switching to S/S braided lines is a good idea. Easier to manipulate and work with than the standard hard lines.
Old Mar 23, 2007 | 08:03 PM
Bumnah's Avatar
i may bit the bullet and switch to SS lines. Any recommendations on ss lines?
I sorta rather just use the oem stuff. If I can't find new washers I'll go with SS lines.
Old Mar 24, 2007 | 04:58 PM
Bumnah's Avatar
found the crush washers at a local machine shop. finally got the damn bolt back in. now let's pray the damn things don't leak
Old Mar 24, 2007 | 06:14 PM
yea just couple that with some high temp rvt and you will be golden.
positron
Mar 18, 2008 01:43 PM
fast240
Oct 21, 2005 07:00 PM
nolimitmr2
Aug 13, 2004 12:37 PM
Monkey Force
May 31, 2003 01:00 AM
