Disco Potato Turbo... Which size?
Old Jul 18, 2004 | 01:06 PM
nolimitmr2's Avatar
I did a search and found two different sizes mentioned. Is it the GT28R or GT28-RS? Whats the difference between the 2?
Old Jul 18, 2004 | 09:57 PM
hitokiri_808's Avatar
the GT28RS is the disco potato. the GT28R doesn't have the disco.
Old Jul 19, 2004 | 04:16 AM
nolimitmr2's Avatar
ok thanx
Old Jul 20, 2004 | 10:25 PM
juggalo_240's Avatar
difference i believe is in the a/r ratio and the bearing setup
Old Jul 21, 2004 | 10:54 AM
pampadori's Avatar
the gt28r is a s14 bb turbo. 310hp.
the gt28rs is a larger turbo with about 350hp tops.
the gt2540r is a 400hp turbo
Shaun
Old Aug 3, 2004 | 01:19 AM
JDMxDrift's Avatar
Burn baby Burn *da-na-na* Disco Potatoe! I heard there is virtually no lag... is that true?
Old Aug 13, 2004 | 01:09 AM
Id-'s Avatar
Id-
umm the GT28R is not even remotely related to the stock s14 sr20 turbo at all... it may have the same bolt pattern on the turbine side and look like a snail but thats where it ends...
the GT28R and GT28RS are FAR more advanced and newer turbos than the T28 ball bearing, they are MUCH more efficient at medium and higher boost levels and can flow more air for a given pressure level... GTx doesnt automatically mean ballbearing; it just means it uses the newer GT cartridge... just like the GT25R has nothing to do with the T25 in the stock S13
the GT2540R is a mismatched turbo; who heard of using a T04S compressor housing on a T25-sized exhaust side? the GT cartridge is more efficient, but the little flow the T25 can do wont be able to match the larger compressor side...
the GT35R is a much better choice for big power, while the GT25R will get you 400hp no problem, 400rwhp with the right stuff
Old Aug 13, 2004 | 09:09 PM
Catharsis's Avatar
dont belive the hype read the compessor maps. plus the disco is too small
ka-tfresh
May 30, 2006 06:26 PM
Michael S13
Feb 22, 2006 06:10 AM
1995 240sx
Jul 30, 2005 01:40 PM
d4vech3n
Jan 5, 2005 08:19 PM
R32
Dec 26, 2004 03:25 PM
