greddy type s problem
Today I just installed my greddy type s bov on my s13 sr20. I had a muffler shop weld on a flange to a pipe that replaces the stock hot pipe. The problem I have is that the car stalls every time a rev up the engine. The idle is fine and I tried tightening the valve, but I had no luck the car just kept wanting to shut off. I was just wondering how some of you guys manage to run an open atmosphere bov. I used to same vacuum source as the stock bypass valve. Any input is appreciated.
I use an HKS.
I use an HKS.
I got the greddy bov brand new last year as an mr2 kit. I bought it at a local shop near my house. The bov worked fine when I had it on my mr2.
Originally posted by toycar
run a blowthrough maf setup. then u can blowoff all u want and it wont die at idle.
EDIT: Sry, answered my own question already. I was right. The search button is your friend
Re: greddy type s problem
Re: Re: greddy type s problem
Originally posted by beatboxer777
get an air flow controller i.e. apexi safc II or greddy emanage. I have an apexi safc II in my ka-t and it keeps the car from stalling with the air-decel setting. In short, it basically tricks the computer to not lean out the fuel mixture when the air is purged through the bov. That's why your car is stalling, because the computer thinks there is too much fuel per air when the bov purges, so it leans out the mixture and the engine dies because of fuel starvation.
Re: Re: Re: greddy type s problem
Originally posted by Kaion1000
The SAFC II should help, but I believe the reason that the engine stalls is because the MAF registers the air that gets blown out through the BOV. The ecu believes that this air is still going into the engine and puts in the extra fuel for it causing it run extremely rich and stall... I could be wrong and I apologize if I am haha
Biggamehit
Dec 11, 2012 04:33 PM
uvamosk
Aug 12, 2005 07:31 PM
kcolyer27
Aug 5, 2004 08:51 PM
