help greddy turbo timer
Old May 6, 2005 | 07:45 PM
BlkTp's Avatar
I installed the greddy turbo timer and the only thing i can't figure out is the ecu speed sensor wire. It's the purple wire for the greddy turbo timer. It's installed on the sr20 ecu. does anyone know which wire it is on the ecu? thanks for the help.
Old May 7, 2005 | 08:45 AM
2fast4y0u's Avatar
the speed sensor is the PIN 32 yellow and green wire....
if you are looking at the ecu, there is that bolt right in the middle. top row to the right there is 2 " sectors " the wire you are looking for is the second wire on the top in the second sector... or the 10th wire on the top counting to the right from the bolt.
0- - - - - - - - - * - - - - - - the 0 is the bolt and the * is your wire
hopefully that helps you
Old May 7, 2005 | 09:08 AM
BlkTp's Avatar
Thanks, I'm gonna go check it out. I'll let you know how it goes.
Old May 7, 2005 | 09:13 AM
2fast4y0u's Avatar
cool ill be here most of the day
stupid work
Old May 7, 2005 | 02:26 PM
BlkTp's Avatar
Hey thanks so much for the help. You were right on with directions. THANKS AGAIN!!
Old May 7, 2005 | 03:36 PM
2fast4y0u's Avatar
no prob glad i can be of help
project180sx
Jul 10, 2006 09:03 PM
middlerth
Jan 15, 2006 02:16 PM
dass2427
Feb 16, 2005 01:39 PM
Judge
Oct 12, 2004 06:55 PM
sil_8dee
Aug 24, 2004 05:01 PM
