how do you change compression
Old Mar 22, 2004 | 11:22 PM
Fill's Avatar
hello
how do you change compression?
sorry im a noob
does anyone know what the stock compression on a KA24DE(1995) is?
Tryign to change it to like 8.5:1
Do you have to buy pistons?
Old Mar 23, 2004 | 11:29 AM
tommyboy's Avatar
Well, you can lower it a little bit by getting a thicker headgasket. But you will have to get a low compression piston set
Old Mar 23, 2004 | 02:02 PM
93RPS13's Avatar
or a head spacer...
Old Mar 27, 2004 | 12:34 AM
SRdave240's Avatar
Or you can raise it by milling the head. That's what I want to do. go from 8.5 to 9.0 on my SR!
Old Mar 28, 2004 | 09:27 AM
daneyan's Avatar
wouldn't that be harmful to the turbo'd engine srdave, i mean ur raising the compression on a turbocharged motor. wouldn't that be bad?
Old Mar 28, 2004 | 07:29 PM
JeromeS13's Avatar
It wouldn't be THAT bad. I'm guessing you want more low-end power (off-boost), which would be produced by that slightly higher compression ratio. Right, Dave? Or, you could just get a turbo that spools faster
Old Mar 30, 2004 | 04:29 PM
Catharsis's Avatar
9.0 isnt to high i would prefer a 8.7 ish personally, especily with that aluminum block. also you better hope you have acess to high octane gas or detonation will be a issue for you
Old Mar 30, 2004 | 08:25 PM
backlife's Avatar
u can also get a copper head gasket or a different crank
Old Apr 11, 2004 | 07:30 PM
SRdave240's Avatar
I want 9:1 compression cause I'm building my car for road racing. They use 9:1 on the JGTC 300 silvia s15. Basically, you can run less boost and get more hp. I always run 93 octane anyways.
don
Feb 18, 2011 11:15 AM
altima/240sx
Apr 13, 2003 11:30 PM
240baja
Feb 16, 2003 01:19 PM
agressiveracing
Northeast
Oct 30, 2002 09:27 AM
rbboyl
Sep 24, 2002 10:02 PM
