ka-t
Old Feb 25, 2007 | 11:25 PM
Sil80 type X's Avatar
ka-t
i have a fairly simple question that maybe someone can help me with. i am a sr guy so i dont know anything about going ka-t. if i was to take a kae or kade and slap a stock sr turbo onto that engine and run stock boost (7.5psi peak) would i have to upgrade the head gasket? would i have to get a computer to control the timing or would that little boost be ok to run totaly stock?
thanks mike
Old Feb 25, 2007 | 11:36 PM
headgasket would prolly be ok, but its always good to be safe, you would definately have to upgrade to atleast sr 370cc injectors..and get an safc at minimum...retard timing i believe..im an sr guy to but i think that info is correct..
Old Feb 26, 2007 | 11:49 PM
yes you must retard timing and run colder plugs with proper gapping. the number 1 cause in failed KA-T's. i would explain to u further, but im a believer in self education at a point. KA-T.org is you answer to the basics. i used one thread from there and another form to build my KA-T.
you will not have to worry about timing untill you want to push past 15 psi. sure it would not hurt to have BTM but its not needed. i adjusted my timing to 15* and have not had any issues. many track days and drifting nights. keep it modest and your KA-T will take care of you.
heres my setup to get an idea of what you need. by the way built for 800 dollars initially
Current setup
xspower T3 ( with z31 backup)
ssac topmount manifold ( spot welded the suspect spots))
Blitz Bov
370cc injectors
safc1
greddy Full auto timer
fmic
earls oil line fittings
NGK copper plugs (gapped to .033)
N60 MAF
255 pump
