ka-t question
Old Mar 22, 2006 | 02:42 PM
240baller's Avatar
Arrow ka-t question
i am in the proses of buying all me stuff to turbo my ka. i have about every thing i need. i bought the apexi afcII, in the manual it doesn't have the 240sx in ther it just has s14 silvias. does anyone know if the ecu wires are the same? when i turbo my car i have all the fuel management figured out i just want to know what other internal work i should do to my motor to insure there is no .......... problems. i am only shooting for 7psi daily and 10 at the max for now. can i get away with just piston rings and a couple gaskets? head, intake and exhaust gaskets?
Old Mar 22, 2006 | 03:24 PM
chiroke's Avatar
do a comression test 1st, then think about turboing it . 7psi is cake stock blocks take around 350 hp daily but depens on how well ur motor is and for wiring the safc i belive is the 3n-b diagram do a search ull find it
Old Mar 25, 2006 | 10:32 AM
240baller's Avatar
ok thanks alot man
Old Mar 28, 2006 | 04:39 PM
All Mighty KA-T's Avatar
If you need any help with the SAFC, ill walk you through it step by step..... i did mine in like 30min or less..... really easy, i've got the ECU diagram if you need help hooking up the SAFC wires to the ECU.
Old Mar 29, 2006 | 06:57 PM
mach5camaross's Avatar
do you know the rings are bad? if not why are you pulling the motor apart for just piston rings at least do a hone/bearing/ ect
Old Apr 4, 2006 | 02:58 PM
240baller's Avatar
well i dont know there bad yet i am going to run a comprision test on my motor in the next week or so.
Old Apr 12, 2006 | 05:30 AM
halfthemasska's Avatar
Yes... definately compression test first.. remember, even if you rreplace rings , there will always be the "next weakest link" in the chain.
with good compression numbers .... 160+ , and all relatively close together.... you can support 7psi very nicely on a stock ka.
also, consider an msd ignition and a blaster coil, gives you a nice clean, accurate spark...
might I ask how many miles are on the motor right now?
Old Apr 12, 2006 | 02:39 PM
chiroke's Avatar
there is no point of just replacing rings if ur not gonna hone or bore the block u might just have a egg shaped cylinder wich will cause also low compression. 7psi is cake stock motor handles 400hp with good tuning some dude reached 500+ on a stock motor with some ugly *** getho setup
Old Apr 12, 2006 | 02:55 PM
240baller's Avatar
aight well that sounds pretty good then thanks for helping. oh and i got like 130k miles on it, mostly highway
