turboing a Ka24de
turboing a Ka24de
Hey guys, Im new to the turboing stuff. but im not retarted either. If turbo the Ka 24de would the computer have to be upgraded and wheres the best place to do it? Thanks alot, Jon
if you push enough boost so that the stock ecu can't manage the newly required fuel flow and other parameters that need to be adjusted, you'll need at least a piggyback ecu so the engine doesn't go kablooie, which would suck big hairy donkey *****
safc can control 50lbs injectors some ppl say it cant some ppl say it can but definatly 480cc from a s15 480cc gives u around 300hp so u can reach AROUND 300hp on safc and 480cc's BTW u will need a z32 maf stock maf maxex at 220 or 250hp not sure all this with the stock ECU
safely, I would use a walbro 255, z32 mafs, sr20 370cc injectors will work, I will suggest a wideband or something more than an safc, but an safc will work. I know people making 300+ on completely stock motors... ka-t.org for some good reference.
What about a 12:1 FMU I also wanna turbo the ka. Dont have much money for I am still in college. I wanna get an e-manage ultimate, but 600 is kinda out of my price range. What else would i have to change out by using a FMU so i dont kablooee?
Originally posted by Jovan
Where can I get a tuned ecu from? you talking about a piggyback? and would i have to get bigger injectors and a bigger fuel pump?
yes, i use a piggyback ( Apexi SAFC )
And yes...you will need a bigger fuel pump and injectors.......i can not stress it enough on how important fuel management is.....do not go cheap with the fuel management, this is very important!!!!
