Not the night for New turbo :(
Yea.................... the log manifold didn't give me the spacing i need. i have to source/build another one that has the flange closer to runner number one...
i was still able to weld my v-band flange setup on... I had issues with the Holset stock v-band because it had an slight Indentation
so i had to think of a way around it.... luckily the mig welder had wire speed and variable voltage, i was able to lay down some some ugly beads lol.. but its air tight ( well i flashed a light through the cracks and filled them in as i saw gaps) blah blah pics below
started to burn through :/ had to reduce the power a bit
yea its ugly,,,, ill grind it away ( i stuffed aluminum foil inside the outlet)
v-band ready to go when i get another manifold
( excuse the oil.. i was pre-lubing the shaft)
That is some custom work, there, Airman Jackson. Lookin' good though. Are you going to smooth everything out? What does the inside near the turbine look like after all the work? Can you do a leak test on that somehow? Lol.
Keep us posted!
Keep us posted!
yea thats the outlet,,,,,,,, i will use a grinder to smooth it out..... its pretty tight now.... but ill go over the outside of it with an tig hitting any gap i missed
man this was the new manifold man..... highly pissed from looking at it i just knew it would give me my space. but boy was i wrong... just as i thought ill need something like this...
so ill search for a week if i don't find anything good, ill build one from jgstools.
thanks man..... dude you should have seen my face... it was as if my world turned upside down and a mighty Roar of the F word came from my mouth
i have had this turbo for about a month now and have been gathering parts etc... it sucked for a bit then i snapped out of it
