phatka-t manifold/downpipe
Old May 16, 2005 | 11:05 AM
ghostman's Avatar
well after much consideration, i've decided not to order from boostdesigns. i've read too many posts/threads on other forums on wait time and customer service issuses. so...... i've decided to go with phatka-t. i'm new to the whole turbo scene. i only want to run 7-10psi max (just want something nice to drive around town in) can anyone recommend a good turbo that will bolt up to their products? i can get a deal on greddy and turbonetics turbos. will any of them work? i'm planning on running phatka-t manifold/downpipe, turbo, 370cc injectors, safc II, vortech blowoff/bypass valve, intercooler, custom pipping, and wal fuel pump. sound good? anyways thanks for the help.
Old May 16, 2005 | 07:36 PM
chiroke's Avatar
dude for 7-10psi dont bother with phat ka-t 750 for manifold and 350 for down pipe for that money u better put down some serious 30 pounds, get something cheaper for your "goal" BTW for 7-10 punds u dont need all that crap u dont need anything at all just a turbo kit no fuel no internals nothing the fouel wouldnt hurt doh P.S im building 400+ ka-t motor
Old May 17, 2005 | 09:55 AM
ghostman's Avatar
no fuel? really? hmmmm i've been "searching" and i read that you should at least upgrade the injectors and fuel pump.... just as an added safe measure. anyways i wanted to purchase the phatka-t manifold and downpipe because i know where to get manifolds from, its the downpipe thats the problem..... i dont know anyone that can custom make one for me. i mean technically i know people, but they're all talk. i dont want to risk blowing anything up. basically i want to stay away from a crappy job.
Old May 18, 2005 | 06:56 PM
chiroke's Avatar
sorry for the reply but it was i typeo or i just forgot to type what i waned to say (happens to me alot) the fuel pump wouldnt hurt to upgrade but no u do not need larger injectors for 7pounds
Old May 19, 2005 | 07:05 PM
ghostman's Avatar
its cool. so do you think the manifold and downpipe would be overkill then? i'm mean it'll work though right? i just want some quality pieces in my custom kit. like i said before i just want something nice... not a track monster. just for my daily driver.
Old May 23, 2005 | 10:45 PM
Sleeperella's Avatar
yo chiroke,
wat is ur set up? and how r u building ur engine? i want to know, so i can have a good idea of wat ill be needing if i am to go down the same path, cuz i wanna boost 300-400hp, wat would be all the required material big and small btoh for the rebuild and the turbo, and where would u recommend getting them from, and the price sums up, thank you,,
Old May 26, 2005 | 11:15 AM
jpos985's Avatar
if you dont want to risk blowing anything up like you said, i would not do fuel...with the right fuel people can safely run high boost on this motor but at the same time its not hard to blow it up at 7psi. if i was you i would definately get an safc, bigger injectors and definately a fuel pump. as for the downpipe, if you got the money for it then go for it, you could prolly find somethin cheaper but its up to you but dont go turbo and just brush off on fuel if you want your car to last.
Old Jun 10, 2005 | 07:39 AM
smokey240sx's Avatar
if your not running under 7psi a simple fmu would be good enough. Make sure you don't spike nice the fmu would not give you enough fuel.
Old Jun 11, 2005 | 05:40 PM
chiroke's Avatar
im doing 3 stages stage 1 rebuild forged pistons stock rods nice bearings, stage 2 fuel sr20 injectors(370cc) safc2 fmu fuel pump i might put that in stage one and i might get a q45 trhottle body ( is it the q45 not sure have to look it up) then stage 3 buy a spare ka head and rebuild it with asome nasty cams and a port and polish job (might condiser bigger valves but 2 much money) oh and double titanium valve springs
glaciuz
Dec 10, 2014 05:43 PM
cooch
May 22, 2007 07:50 PM
Motegi
Dec 27, 2005 12:24 AM
TurboEvo
Jun 10, 2003 02:29 PM
RyceRacerX
Dec 11, 2002 01:40 PM
