Profec-B Spec II questions.
I just put the unit in my car and it mounted very nicely and was very easy to install.
My question is, when I turn the car off the controller stays on. Is this supposed to happen? If not what should I check for?
Also, does anyone have any settings they would like to share? I'm looking to run 12psi.
Thanks.
Edit - Also, i'm not sure if it's supposed to read as such, but at idle and when i let off the throttle the display reads -99 (in psi display mode)
Thanks.
sounds like you wired it to a permanent power line, you need to wire it to something that comes on when the key does. As for setting search around i just posted some setting recently in the turbo section. And -99 is what you want at idle.
dass2427
Feb 16, 2005 01:39 PM
