S14 ECU Problem
Old Mar 19, 2004 | 10:44 PM
Pretzel King's Avatar
S14 ECU Problem
I posted this in the other forum but nobody said anything.......
To make a long story short, the engine shop calls me and says that they dont know what wire on the ecu is the constant there for the ecu resets itself everytime the car is turned off and on again. The fuel managment system still holds all the fuel maps in its memory and I guess the way they described it.
I have to drive the car like 400 miles home on tuesday and im alittle worried I dont know much bout ecu or electronic problems is this something I should worry bout driving it home??
Old Mar 20, 2004 | 12:57 PM
Romeyo07's Avatar
if your car is in normal running conditions other than your ecu you should be fine. nothing gets erased when you reset your ecu. kinda like when you re-install a program on your computer, it just goes back to its original form.
Old Mar 20, 2004 | 08:26 PM
so it should be ok then you think?
Old Mar 21, 2004 | 10:32 AM
Romeyo07's Avatar
yup
Old Mar 21, 2004 | 10:50 AM
sweet!! thanks alot
Biggamehit
Jan 21, 2013 08:24 PM
RTP_EVIL14
May 1, 2006 02:07 AM
vortxxe
Apr 29, 2006 05:22 AM
uvamosk
Aug 12, 2005 07:31 PM
Yusuke
Jun 9, 2003 09:19 AM
