stock KA pistons w/RB T3 turbo
Old Nov 16, 2005 | 01:20 PM
zenkizen's Avatar
is it absolutely necessary to replace the stock KA24DE pistons when using a RB T3 turbo or can the stock KA pistons be doable?
Old Nov 16, 2005 | 02:55 PM
nsn240's Avatar
unless you want your engine to explode... i suggest changing them
make your sig smaller
Old Nov 16, 2005 | 08:34 PM
chiroke's Avatar
a stock ka can hold 400hp before the ringlands+ rings blow a t3 is nothing and the size of the turbo doesnt mean anything a rb t3 t25 t3/4 wich is bigger etc depends how much u boost it and make sure u add bigger injectors or fmu but a t3 is fine
Old Nov 17, 2005 | 12:29 AM
Levi SPL S14's Avatar
KA can handle 12psi stock headgasket.
You can actually go more with metal head gasket and not need to change internals.
Old Nov 17, 2005 | 10:44 AM
chiroke's Avatar
u dont measure with psi u measure buy hp 12 psi from a t25 is way differeng than 12psi with a gt35r
Old Nov 17, 2005 | 12:09 PM
nsn240's Avatar
just about to say that...
Old Nov 18, 2005 | 12:51 AM
well PSI is PSI no matter what
CFM is different.
Old Nov 18, 2005 | 10:31 AM
chiroke's Avatar
no its not 15 psi of a t25 will run hotter than off a bigger turbo hot= less hp, smaller turbos at high boots arent very efficient
Old Nov 18, 2005 | 03:30 PM
^ well thats a given.
Its the amount of air that changes not the pressure.
Example.
Meanin that at 12psi on a T25 moves 14CFM of air.
So at 12psi on a T28 i would move 20CFM of air at the exact same boost.
The numbers arent the best but thats the jist of it.
Old Nov 26, 2005 | 10:53 PM
bottombunk's Avatar
listen to levi, he is right. also a ka doesnt hold 400hp, all motors are not alike. it might hold 400hp. good tuning is recomended.
Old Dec 6, 2005 | 01:33 PM
TorqueFreak240's Avatar
yeah im not sure i would try and hit 400hp on stock internals but you can easily get to 270whp of stock internals no prob with fuel managment of course. I've seen plenty of dyno's of people hitting that with the SR20 T25. I think those are some pretty good numbers IMO!
Old Dec 6, 2005 | 01:48 PM
T25 is a bit to weak for KA, it dies out way before redline, i suggest T28 or T04Z.
Old Dec 14, 2005 | 12:26 PM
flyboy367's Avatar
lot of good info in here. i was more of a supercharger guy but once my 240 is in my hands im looking to go turbo.
Old Dec 27, 2005 | 03:39 PM
2forty2sick's Avatar
hey zenkizen, what kinda addon is that on the rear? who makes and where did u get it? it looks nice!
Try that in a PM next time.
Thanks,
Levi
Old Jan 2, 2006 | 09:22 AM
usdm240's Avatar
recommendation: dont over-boost the RB T3. the ceramic turbines dont last over 12psi. i found that out the hard way...
