Walbro 255 on S13 question
I don't own a 240 right now, I own a previously turboed honda civic. Unfortunately though, I ran 15psi and a rod snapped, and I put 4 holes in the block. Anyways, for a next project I'm almost definitely going for a S13 w/ sr20det and upgraded turbo.
My question is this. What are the part number/install kit part number for the walbro 255lph pump in a S13? I'm hoping I can use the one from my civic since fuel pumps aresomewhat universal. This pump itself is stamped GSS-317. (There might be three other numbers after the 317 part of it, it's still in my car). Also, I was wondering if someone could please post a picture of what they recieved when they purchased their Walbro 255 high flow pump so I could compare them.
Thanks alot.
Thanks alot.
just pull the one off the civic. when i ended my civic and started finishing the 240 i just pulled my walbro and put it on the 240. everything fits pretty good. the only thing your going to need to do is cut the rubber gasket that holds the bottom uf the pump. this allows you to put the net back on it. or at least i had to do this. good luck.
jungle
01-29-2008 08:00 PM
RandyJordan
For Sale - Wheels / Tires
04-15-2007 07:20 PM
jsigone
04-22-2006 11:11 PM
Unholy FD3S
10-17-2005 08:33 AM
