will this manifold work
Old Aug 14, 2003 | 10:13 AM
Mr. Spool's Avatar
I am trying to find out if I can put a turbo manifold off of a 91 240 onto a 95 240 and if not what is the differences. when I put my cars next to each other I dont see the big difference. thanks
Old Aug 14, 2003 | 01:05 PM
driftmania101's Avatar
it wont fit. different heads
Old Aug 15, 2003 | 06:57 AM
Mr. Spool's Avatar
The heads should be the same. they are bolth the same engine. they are bolth ka24de's unless there is something that I am missing. If you could enlighten me I would apreceate it.
Old Aug 17, 2003 | 08:42 PM
SHIFT_Lock's Avatar
a s13 stock manifold will bolt onto a s14 motor i've done it a million times. when you put a s14 motor into a s13 car thats what you do. change manifolds and dist. and harness and ecu all from a s13. just use the s14 long block so yes it will work.
Old Aug 18, 2003 | 07:12 AM
Mr. Spool's Avatar
thanks for the imput that helps more than you know.
cleland500
Jan 15, 2003 05:33 AM
7mgte in a 240?
Jan 4, 2003 03:09 AM
n2zoomn
Aug 22, 2002 12:55 PM
n2zoomn
Aug 22, 2002 12:54 PM
RNN14
Feb 18, 2002 10:06 PM
