How would 17s look on a 95 240sx zenki style Need advise.
Size is 17x8 + 38 offset front and 17x9 + 38 offset rear.
They are some jdm rims look like the mesh volks for a good price 4x114 and 5x114 multi bolt pattern so I can always sell them down the line. What do you guys think. Here are the rims and specs http://img.photobucket.com/albums/v4...pec/aa54_1.jpg Bolt pattern is dual 4/5x114.3 Size is 17x8 + 35 offset front and 17x9 + 35 offset rear http://img.photobucket.com/albums/v4...pec/6269_1.jpg Size is 17x8 + 38 offset front and 17x9 + 38 offset rear. http://img.photobucket.com/albums/v4...pec/1593_1.jpg Bolt pattern is dual 4x114.3 Size is 17x7.5 + 29 offset front and 17x8.5 + 29 offset rear http://img.photobucket.com/albums/v4...pec/71d7_1.jpg 17x7.5J +38 front, 17x8J +32 rear. 4x114.3 So tell what you think. |
dont get them.
Terrible offset, your car will look sunk like them z28 camaros
Originally Posted by 1993Coupe
(Post 321586)
dont get them.
Yeah those sizings & Offsets are kinda lame. Mesh wheels don'y look too cool on Fourteens. Multi-spoke is nice though.
Originally Posted by japspec
(Post 321585)
none of them, offsets are way to high for an s-chassis. if your comming from a fwd world. read up on wheel offset.
only set 2 and the last set will clear shocks/coilovers. i would suggest going atleast 10mm offset less on most of those wheels to play it safe. if you are stuck on getting something i would get the second set, and run 5mm spacers all around.
get 17x9's in front & 17x9.5 in back
Originally Posted by Iwanta nismo
(Post 321640)
or get 17x9 around with the same offset and tire size and have the ability to rotate them as they wear. different wheels have been discussed in other threads, feel free to browse through and find something that you are fond of
you can always go with the sure-fire win.....5Zigen FNs blah blah etc
(Post 321660)
What rim would you suggest.
(Post 321660)
wow.
i kinda wanna lock this thread, at the same time helping you out seems like a good idea. so for the 3rd time i will quote myself.
(Post 316484)
so...he has an S14 and wants a inexpensive, decent wheel and tire setup.
wheels: MB motoring weapons (17x9 +17) MB motoring competitions (17x9 +27) Nissan R33 GT-Rs w/ 30mm spacer (17x9 +0) 5 zigen FN01R-Cs (17x10 +12) anywhere. CST d-spec (17x9.5 +15) CST Zero 1 Hyper (17x9 +30 / 18x9.5 +15) JIC magic j force 05 (17x9 +15) JIC magic j force 07 (17x9 +15) also check out www.rbmotoring.com off the top of my head. http://club240.com/forums/showthread.php?t=39149 http://club240.com/forums/showthread.php?t=38988 |
