How would 17s look on a 95 240sx zenki style Need advise.
Size is 17x8 + 38 offset front and 17x9 + 38 offset rear.
They are some jdm rims look like the mesh volks for a good price 4x114 and 5x114 multi bolt pattern so I can always sell them down the line. What do you guys think.
Here are the rims and specs
Bolt pattern is dual 4/5x114.3 Size is 17x8 + 35 offset front and 17x9 + 35 offset rear
Bolt pattern is dual 4x114.3 Size is 17x7.5 + 29 offset front and 17x8.5 + 29 offset rear
17x7.5J +38 front, 17x8J +32 rear. 4x114.3
So tell what you think.
only set 2 and the last set will clear shocks/coilovers. i would suggest going atleast 10mm offset less on most of those wheels to play it safe. if you are stuck on getting something i would get the second set, and run 5mm spacers all around.
or get 17x9 around with the same offset and tire size and have the ability to rotate them as they wear. different wheels have been discussed in other threads, feel free to browse through and find something that you are fond of
wow.
i kinda wanna lock this thread, at the same time helping you out seems like a good idea.
so for the 3rd time i will quote myself.
check these links out as well.
http://club240.com/forums/showthread.php?t=39149
http://club240.com/forums/showthread.php?t=38988
so...he has an S14 and wants a inexpensive, decent wheel and tire setup.
wheels:
MB motoring weapons (17x9 +17)
MB motoring competitions (17x9 +27)
Nissan R33 GT-Rs w/ 30mm spacer (17x9 +0)
5 zigen FN01R-Cs (17x10 +12) anywhere.
CST d-spec (17x9.5 +15)
CST Zero 1 Hyper (17x9 +30 / 18x9.5 +15)
JIC magic j force 05 (17x9 +15)
JIC magic j force 07 (17x9 +15)
also check out www.rbmotoring.com
off the top of my head.
wheels:
