wheel adapters
have some one use wheels adapters how did they work. any negative experiences? are they safe? i want to know from people that have use them.
because alot of people said that they are not safe but they only read it in a book or some one told them. thanks alot for any help that i can get :smilie_thumbsup: |
H & R type and slip on's (15mm with extended studs) I have used.. no issue.
However getting the right offset wheel will negate needing to run them. The biggest issue with running spacers that are about 15mm is... your car becomes unsafe if they are slip on style used with stock lugnuts. IF you MUST use spacers, I suggest making sure they are hub-centric and bolt to the spindle. |
Originally Posted by lalo
(Post 393279)
because alot of people said that they are not safe but they only read it in a book or some one told them. thanks alot for any help that i can get :smilie_thumbsup: In any case, I use a set of 5mm spacers on my stock studs ( I tried 10, but could only get the lug nut on 4 turns which IMO is not enough). I needed the 5mm's because the lightweight wheels that I bought had a crappy offset (+40) and the front tires were only like 1/4" from the coilover spring, and when taking a hard turn on the track or going over a elevation change they would rub. |
Hey if you are planning to buy any of em you can get them at discounted price here http://www.theautopartsshop.com/auto/nissan.html
| All times are GMT -7. The time now is 04:38 AM. |
