Anyone know how to make a kill switch?
Old Apr 27, 2005 | 06:54 PM
bw54867's Avatar
for an s13,don't know where to start,i would like it to have a hidden switch,what type of switch should i buy?should i connect it to the ignition,fuel pump,or starter? should i connect it close to the dash or in the engine bay?
thanks
Old Apr 27, 2005 | 07:08 PM
Mika's Avatar
probably just use a rocker switch, single pull single throw level arm switch, about making a kill switch im not sure though sorry
Old Apr 28, 2005 | 03:37 AM
wikd240's Avatar
any of the methods you mentioned above will work... what i would suggest is that you do it from the starter... go under the hood and cut the starter wire... splice in 2 wires from there... connect one side to the wire on the starter the other side to the wire from the harness...then run the 2 wires from there to where ever you want to install the switch... i would suggest that you hide it good... under the center consol where the shifter is... or something like that... make sure that it is a heavy duty switch... not any of the cheap 15 amp ones from autozone... go to napa and get a 50 amp toggle switch... wont burn out as easy... the starter carries a lot of current and i would not trust it to a cheap switch... make sure that the wires are covered in loom or electric tape all the way...
flip the switch and try to start...
Old May 15, 2005 | 10:45 AM
backlife's Avatar
you can also get switches that use a key
and u can also wire it to the fuel pump or hell just the battery
Old May 15, 2005 | 01:04 PM
djradam's Avatar
don't do it to the battery, unless you like setting your clock each time and your radio presets. and you'll need a HEAVY DUTY switch
FuriousZ
May 11, 2008 12:23 PM
CNDC
Sep 18, 2006 10:03 PM
kable
Jun 6, 2004 12:01 AM
-HyJynX-
Oct 14, 2003 12:40 PM
DriftS14
Apr 26, 2003 02:06 PM
