Help with ECU
Old Mar 8, 2006 | 04:17 PM
allenvdang's Avatar
Help with ECU
I', planning on installing a nav unit into my 90 fastback. I was wondering if anyone had a layout of the ECU for the 90 fastback.
Old Mar 8, 2006 | 05:11 PM
Preston's Avatar
Why do you need the ECU layout? All you should need is standard radio wiring layout. Or is this the kind that has performance meters built into it?
Old Mar 8, 2006 | 05:14 PM
allenvdang's Avatar
the nav requires me to tap into the spped snesor wire. so i need to know where that wire is in the ECU
Old Mar 9, 2006 | 01:12 AM
Moved to the "Audio/Video" section.
Old Mar 9, 2006 | 06:46 AM
Preston's Avatar
Just splice it from the sensor. Or follow it up into the car and do it from there. There's a sticky in the drivetrain that has how to remove the 5th gear limiter....and it'll say which sensor is the speed sensor, just use that and follow the wire up.
Biggamehit
Jan 21, 2013 08:24 PM
RTP_EVIL14
May 1, 2006 02:07 AM
Pretzel King
Mar 19, 2004 10:16 PM
240sxFan
Mar 4, 2004 05:19 PM
doua
Sep 26, 2002 09:46 PM
