Jessicas 240SX
Originally posted by Cape 240
Okay, the wire goes into the fire wall. To the left of the block, down pretty low there is a tube that comes out and points down. And there it ends, i think it has to do with vents. You go through there, and the wire will come out up near the passenger's feet, next to the center console. Run it from there, behind the panels, under the plastic sill-guard(and rug), behind the rear panel, and pop it up behind the rear seat, from under the rug.
Here is a short, crappy quality video to show you (kind-of) where in the firewall it is.
http://media.putfile.com/Speaker-wires
If you look DEAD CENTER in this picture (below) You'll see a silver braided wire, its going around a rubber seal, into the firewall.
I feel like such an *** saying this...but I cant think of any other way to say it so I appologize ahead of time.
He's using a steel-braded wire cover. I dont think that'll be wearing away any time during my life. Might screw up the gourmet a lil tho.
g's its like a bunch of horny kids in here. But seriously you should get some for this cause the 240’s are a ***** to work with.
Anyway if the car is an automatic then you can go directly through the firewall where the clutch peddle goes. My car has the ABS system, and there is no room on the passenger side to get my arms in there to run a wire. Also when I ran my ground; I grounded the wire to the hump underneath the rear seat. (up high to make sure I did not run into wires or gas tanks… boom!)
Also for best results and the least amount of noise run the RCA wires and the power wires away from each other preferably not crossing. The 240sx is a noise powerhouse when it comes to aftermarket stereos. I ran all 5 of my wires through the center console but I also kept the wires separate; I now have absolutely no audible noise in my system. Also I ran extremely high current 0awg wire to compensate for not having a cap.
Heres what Im looking at to buy...any advice?
Subwoofers:
Rockford Fosgate RFZ3810 10-Inch Subwoofer
-or-
Sony XS-L107 10 inche Sub
Speakers
INFINITY 6402CF 4x6 Speakers (front)
AUDIOBAHN AS46Q 2- WAY 4X6 Speakers (rear)
Amp
Blaupunkt PA2200 Amplifier
Subwoofers:
-or-
Speakers
Amp
Infinity SOUNDS better than AudioBahn.
Blaupunkt amps have no *****.
Give me a price range and tell me what all you want/need; and I’ll give you a recommendation.
So far Ive collected 400 dollars...expected to reach 700 before the deadline of the 9th. My personal favorites are infinity and RF but that doesnt really matter cause all I know how to do with audio is install it (barely even that).
I always thought that wire covers had a cover over them to ease install and other reasons...I thought the order of insulation would be:
|outer insulation| |wire cover| |wire's insulation| |wire|
Its very heavy wire, nylon coated, steel braided, insulated, then wires. There is also an 80ohmz fuse in-line.
I can't remember which type it is, i think its Monstor Cable, but something tells me it was another brand. Don't really remember.
and don't worry, i know what i'm doing. no fires, why do you think its right at the "fire wall" ? god ...
Don’t get me wrong, Infinity is good stuff; it’s just that it is over priced and poorly made. RF on the other hand is MUCH better stuff but you will still pay for the name.
$700 is a good amount; from what I gather you need 1or 2 subs, a sub amp, 4 speakers 4x6”, wire kit, RCAs, and maybe an amp for the speakers?
My first thought for subs would be Boston Acoustics, G2 series subs. These subs don’t need a lot of power but will absolutely rattle you and your car. Also they are inexpensive.
http://www.bostonacoustics.com/car/c...&family_id=107
For speakers I would recommend Memphis audio 4x6” co-axels; as they have an inline crossover for sound quality. Also they are VERY competitively priced.
http://www.memphiscaraudio.com/produ...ails.asp?id=18
As for amps I am just going to assume that you only need one for the sub/subs. I am going to recommend a Memphis 16-MCD500. This amp will drive 1 or 2 Boston Acoustics subs with ease and efficiency. If you use the boston Acoustics subs, then you need to use SVC (single voice coil) subs. If you use one then the amp will put out 250 Watts RMS and if you use 2 (and run them parallel) then it will put out 500 Watts RMS.
http://www.memphiscaraudio.com/produ...cat=&id=24&p=2
All of the items I have listed are on eBay for Very good prices.
Remember this is just my recommendation and the end product is your choice. I have a lot of personal experience with the 240sx sound, and with all the products I have listed for you. Some may not agree with me, but I know what I like and I know what sounds good to me. I have had many satisfied customers through the years.
