Need Some Info on Security Systems
Hi,
I've been looking for a good car alarm but don't know much about them.. How does a security system work if I don't have power door locks? Will I need to have them installed? For the systems that come with remote start, will that work on a manual transmission? I've tried looking on the manufacturer's sites (clifford and viper) but they don't seem to answer my questions..
So any info would help!
THANKS!
THANKS!
http://www.the12volt.com/index.asp
FYI
If like to have keyless entry them solenoids will have to be installed with your alarm....the best alarms...???
Clifford....expensive but nothing but the best,Baby!!
FYI
will its possible to install power door lock, you need something called a "ACTUATOR" i got mine off a speaker shop and they work preety well. (I dunno if i spelled that right whatever) M-e ways ways for the power door locks yea the word for today is Actuator
Hope all goes well
Dante
Hope all goes well
Dante
Thanks, well, i'm trying to decide whether or not I really want power door locks.. it depends on how much more extra it's gonna cost to have those installed.. as for the alarm system, what I want to get is the clifford matrix RSX 2.5-- I really like that 2-way paging system, and this one doesn't have remote start. Anyone know any places I could find a good deal on this system for? tried eBay but no luck!
Originally posted by Waynehead05
http://search.ebay.com/clifford-RSX_...QsosortorderZ1
Thanks
The door locks sould not cost more than 75 per door there pretty easy to do, as for the clifford there good but there not the true clifford ther just a DEI product its the same as any viper or avital some even say avital on them if you take off a sticker. theres not doubt that there good but there are illigal to install into a standard vehicle. I have sold compustar and they work very well and they have an awsome 2 way system and can do standards.
remote start is an optional feature, not an integrated part of the security system, so it's like "window rolldown" feature - you can skip it if you choose not to have it. And IMO I wouldn't bust a remote start on a manual transmission - it's too risky, the things that can happen if you try to start the car and it was accidentally left in gear.
STEARNZY is right about the Clifford thing - from what I understand, there's the real Cliffords, then there's the relabeled versions Clifford bought from other manufacturers, so that Clifford could expand their product line or something.
no clifford was bought by DEI and DEI just uses the clifford name
the starters on standards isnt dangerous as long as there installed properly they should have a resevation mode which makes you get out of the car while its still running then when you shut the door the car will turn off that way when the car starts its not in gear and the ebrake is on iv installed many and there great
Originally posted by LaDyInRed
Thanks.. but i'm looking for the matrix RSX 2.5 cuz that one doesn't have the remote start (i don't need it since it won't work for a manual).. however, i guess if those are good prices I could get it and just skip the install of the remote start?? will that work out?
Thanks
Thanks
this way you could have remote start on a manny.
remote start does work on a manny and you can bypass the clutch. search on the bypassing of the clutch... it takes less than 3 minutes if you know where to look around the firewall.
Anyway, thanks for all the info guys..
Why would they be illegal?
As for the remote start, I still think I'll pass on it just because I don't wanna deal with all the hassle of getting it done.. BTW, what would be your take on those clifford systems being sold on eBay? I know that they're B-Stock (refurbished) but would you guys trust their quality?
It's a safety issue, much like how technically it's illegal to mount a video monitor that is in the drivers view, which can operate while the car is moving. Usually video monitors have to be tied into the E-brake to ensure that the driver is using the monitor only while the car is parked... but if you think about it, what about those factory navigation systems they mount in dash?
IMO when you go refurbished, it's hit or miss. Some units only needed a new case, other might have had some weird problems in the circuitry. If you're buying something to protect your $XXXX.XX car (with that sweet paint job, might I add) might as well at least invest in a new unit
