Running power in dash for electronics
Old Sep 18, 2007 | 09:06 PM
Enlefo's Avatar
I'm about to install my EDFC and I'm trying to figure out what I want to do for power. Right now I have a AEM UEGO power by my stereo power and I want to give that dedicated power too, as well as power for an in dash monitor for when I put a PC in the trunk. I'm sure they'll be other gadgetry too when I go SR or KA-T.
The EDFC requires both constant and ignition power. I'm going to just run a power wire from the battery into the cabin for that (with fuse of course!)
I am not sure what the best thing to do for ignition power is. Take it from the ignition wiring under the steering wheel? Anyone who has put in a bunch of electronics into there ride have any tips or suggestions?
Old Sep 18, 2007 | 09:09 PM
i don't have ac or heating so i just used the power for the climate control and blower motor when needed.
Old Sep 27, 2007 | 10:30 PM
Initial Daniel's Avatar
Yeah a good idea would be to take it from the ignition...that's one of the best spots. If not, you can always get 12 volt behind your radio, or somewhere else that provides it. Just make sure it isn't to a switch that can turn on/off.
Ignition harness is the way to go, though.
Old Oct 1, 2007 | 12:16 AM
Enlefo's Avatar
Cool. I'm running power straight for my battery for constant power but I also no a power line that's only on with the ignition. So I'll just grab it from under the steering wheel I guess.
Old Oct 1, 2007 | 11:29 AM
You can get both constant +12 and switched acc from under the steering column. You can check to see what colors they are, then meter the wires to be certain. It'd be a little cleaner that way too than running a wire from the battery through the firewall, then to your device. Thats just my opinion though.
Let us know how it turns out and if you need any more help. :]
Old Oct 1, 2007 | 03:20 PM
Enlefo's Avatar
I've tapped into those wires before when wiring up my pager alarm. I was just worried about running 3-4 things off that wiring and figured a dedicated circuit would be better. I'm gonna do that, wire up my edfc and relocate my battery to the trunk when I feel like going on a little wiring binge.
ErnGotti
Feb 12, 2011 04:18 PM
kang128
Nov 21, 2004 04:35 PM
yektik99
Nov 16, 2004 12:48 PM
bztech
Nov 24, 2003 09:55 PM
boro240
Oct 17, 2002 09:01 PM
