stereo issues to fix
First, I have a Nissan cd/tape radio I bought off eBay that was for a 98 Altima. Fits nicely. The tape and cd play with no sound and the illumination doesn't work. So I wanted a stock wiring diagram for the Altima to figure if anything else needs to be hooked up. I have an aftermarket diagram and have looked in the Chilton's. Those were not sufficient for the info I was looking for.
Second, I have the se which has the separate tweeters on the doors. When I turn up the radio, the bass can be heard through the tweeters. What capacitor do I need to fix this problem.
Suggestions would be greatly appreciated.
Actually the wiring is all correct. But the unit is the one that has a problem with it since I bought it used off ebay. And I'm expert in electrical wiring. i did have a diagram but it only gave me the main harness connections and I wanted to know the other harness connections to the stock amp. For just my info.
o well if ur asking me for colors then i have no idea. i ussually just use a ohm meter to find the 12v, grd, and 12v cont. stock amps suck so i just throw them out and put in a better one. =P sorry im not an "expert" or anything.
