Stereo Repositioning
Old Dec 7, 2004 | 05:51 PM
240s13.5's Avatar
how would one go about installing there stereo into the heat/cooling vents on dash in the middle. thanks everyone!
Old Dec 7, 2004 | 08:16 PM
djradam's Avatar
i would guess a little bit of work. can't tell you for sure, but you probably have to do quite a bit modification to secure it. and you MIGHT have to extend wires.
Old Dec 8, 2004 | 03:14 AM
check in this forum for a thread by Treyz about his dash setup
Old Dec 8, 2004 | 11:59 AM
91coupe's Avatar
rip the vents out and get a piece of ABS plastic and cut it so it fit perfectly in to the opening, then extend your wire harness and possibly the antennea. Take the DIN cage from the deck and center it on the ABS cutout and trace it. Cut the rectangle out and mount your DIN cage, connect your wires and secure the ABS piece into the vent hole. You might have to fasten the ABS from behind the dash.
If you have any questions on wiring the deck i can help also, I am a mobile electronics installer
Old Jan 6, 2005 | 01:55 PM
wikd240's Avatar
http://www.club240.com/forums/showth...dio+relocation aught to show you everything you need to know...
AzzySK
Oct 12, 2002 01:52 PM
KingJimmyJones
Aug 3, 2002 07:54 PM
pinoy nismo
Apr 8, 2002 10:40 AM
Thanatos-S13
Mar 6, 2002 02:26 AM
Sinfestboy
Feb 11, 2002 06:47 PM
