240 release bearing
Old Apr 22, 2008 | 03:24 AM
emartinez's Avatar
240 release bearing
hey all im buying a 240 and the only problem is the release bearing is stuck. not letting the car shift into any gear. how easy is it to fix this problem. anywhere i could read up on it?
thanks.
Old Apr 22, 2008 | 03:19 PM
the release bearing is job is to push in on the Pressure plate diaphram. what that does is disengages the clutch from the engine and allows you to shift gears
if the Release bearing is broken/seized at all it will make a squealing noise.. and yes it will be hard to get into gears.
your issue sounds like the clutch is not properly being disengaged which means you probably need to bleed the clutch system
there is no write-ups on the release bearing itself.. but inside of the HOW TO section. i have a clutch swap write-up... check that out.
djradam
Mar 9, 2005 01:27 PM
ninedy_to_koop
Sep 9, 2004 01:43 PM
180SXcoolguy
Mar 19, 2003 02:39 PM
HOK
Dec 12, 2002 02:56 AM
Mischief
Mid Atlantic
Nov 3, 2002 01:31 PM
