Clutch Choices
Clutch Choices
ok i have done some research on clutchs. it seems act makes a very quailty street set-up. i am looking at buying the extreme clutch that holds 333ft lbs. i have read that they under rate thier kits by a little. my set-up now is basically stock but i plan on running the JGS kit with aem ems maybe pushing 15psi if i can get the tune i want. i am trying to get my car turbo ready so when i turbo it there are LESS suprises (i know there will still be some) how does everyone like the act extreme clutch? and who has the best prices?
I'm using a spec stage 3 clutch and fidenza flywheel, I got this since the feel on my buddies act clutch is kind of strange when going from stock, also the spec clutch are the most stock feeling while maintaining th ability to hold a good amount of tq. If you do plan on running 15lbs of boost you may need to look at something a bit more stout. Most poeple running that much boost are putting down numbers higher than 325 lbs of tq., unless you want to replace your clutch fairly regularly.
YangpaNemsay
Aug 3, 2004 10:55 PM
