clutch pedal sticks to the floor
Old Jan 2, 2007 | 05:55 PM
Dstyle's Avatar
what would make the clutch pedal stay down to the floor and not return up??
i thought it might be the slave cylinder, but im not a mechanic.
are these cars hydraulic or cable??? i was thinking it might be the clutch cable??? throw out bearing????
help me out here, thanks
Old Jan 10, 2007 | 03:27 PM
cgoldhill's Avatar
Could be your clutch master cylinder or clutch slave cylinder. Check both to see if they are leaking.
Old Jan 10, 2007 | 03:34 PM
Master, slave, try bleeding first
Old Feb 2, 2007 | 06:36 AM
cheryred240's Avatar
clutch on floor
well the system is hydro , not cable . the clutch master is your likely cause but as a good rule of thumb i would replace both the master and the slave . thats what we recommend at the shop when we do them. sometimes replacing the master stirs up trash in the lines and can cause the slave to go out . if you replace both make sure you blow out your line to get the trash out of it .
Old Feb 12, 2007 | 04:40 PM
^^^wtf? spam has really gotten outta hand here. but yea try bleeding first. probably will have to replace.
Old Feb 21, 2007 | 01:22 PM
NiSmO Knight's Avatar
Originally posted by Floopy
Catherine Zeta Jone Throatjob!
http://Catherine-Zeta-Jone-Throatjob...p?movie=276827
OK, since when the hell did idiots start doing this crap?!?!?! WTF is your problem Floopy?
THIS IS A CAR FORUM, TAKE THE **** SOMEWHERE ELSE YA F*KIN NUB!
Sorry, had to vent. I been on here for years and now kids sign up to spam ****? WTF?
Old Feb 21, 2007 | 07:49 PM
re037's Avatar
club240 has a lot fo spam for the past few months and we're about to make a move to a new forum...
Old Feb 21, 2007 | 07:59 PM
zenkislider's Avatar
bleed it, and yes we all know the spam is here. Work in progress.
Old Feb 21, 2008 | 05:02 PM
greed77's Avatar
Ok, I'm having the same problem and am willing to accept it's the master / slave cylinder.
My question is this: is it hard to replace those? I'm going to the auto parts store tomorrow to pick up both (because cheryred suggested replacing both could save potential headaches) and also a Chilton's. I'm not horribly mechanical but am no idjit by any means. Anything I should look out for or be sure to pick up while I'm there to save myself some headaches?
thanks!
Old Feb 21, 2008 | 06:17 PM
thanks!
if you haven't bled it already you should do that first. but no replacing both slave and master cylinder are not hard. if you do replace both cylinders it would be a good time to first drain line then replace them and refile with new fluid. lastly be sure to bleed the line at the slave cylinder.
Old Feb 21, 2008 | 06:22 PM
greed77's Avatar
Wait, brakes? Are the clutch hydrolics tied into the brakes?
Old Feb 21, 2008 | 06:25 PM
no my bad i stated typing that then stopped for a few min and forgot what i was typing. my bad.
Old Feb 21, 2008 | 06:49 PM
greed77's Avatar
Lol, it's all good. It's still easy? Drain the line, install new cylinders, refill lines, bleed at slave? That's it? Sounds WAY too easy. :P
Old Feb 21, 2008 | 07:56 PM
acfalconhawk's Avatar
don't forget the clutch dampener if you haven't already taken that out.
Old Feb 22, 2008 | 03:52 AM
greed77's Avatar
I haven't started yet... is the dampener something I should replace, too? Or is it just something that'll have to come out to make the happen?
