Flywheel bolts/short throw shifter
Old Jan 27, 2005 | 08:20 PM
Pedrolies's Avatar
i recently replaced my clutch and got the flywheel resurfaced. now im putting it back in and i have the shop manual, but i cant find anywhere what im supposed to torque the flywheel bolts to. i was just wondering if anyone knew or had some idea.
also, i was wondering if theres any way to make a short throw shifter while everything is out of the car? i know a lot of people just cut down the shifter, but i was looking for more of an actual solution. anything would help though. and does the shifter **** actually come off? i couldnt get it. thanks.
Old Jan 27, 2005 | 10:37 PM
Re: Flywheel bolts/short throw shifter
The flywheel is bolted down with 105ft/lbs in sequence.
As for "making" your own short shifter, unless you have machine tools there's no way - a short shifter repositions the pivot point of the shifter higher than stock - on our shift levers, the shifter is a one-piece affair so there's no way to move the pivot point short of grinding the shift lever straight, machining a new pivot ball, then attaching the ball to the shifter at a higher position than OEM
Old Jan 29, 2005 | 10:48 AM
Pedrolies's Avatar
thanks. i figured there wasnt any way to do it. i just thought id ask while the transmission is still on my garage floor.
Old Jan 30, 2005 | 03:39 AM
np
silentvoice19
Oct 22, 2006 06:35 PM
jcl666
Jun 10, 2006 03:28 PM
hachi
Jul 26, 2005 11:10 PM
Slidin_Silvia
Feb 20, 2005 09:54 AM
zilvia14
May 21, 2004 11:56 AM
