Gear Oil and Tranny Oil How To?
get a FSM, it says in there. theres 2 plugs on the manual tranny, one at the side, one at the the bottom. drain it from the bottom plug. then pour the new stuff in the side up to the level of the hole. it takes 2.4 litres....i think the dif is the same method. dont use gl-5 and dont forget to plug the drain before pouring it in the side
Originally posted by l2aine
For the tranny, I heard you can just pour the gear oil down through the hole that the shifter comes out of (when you take the shifter off, of course) can anyone confirm this?
i got the pump and did it when i put in my clutch and flywheel went a lot easier i did one bottle without the pump... not one of my smarter ideas.
As long as were on the subject of oils. Whats the best weight/brand for a stock lsd? I'm leaning towards Redline like most people say, but anyone know which is best for drifting and what weight?
thanks in advance.
thanks in advance.
good stuff. I'll prolly order that. 1 last question before i do that. whats the story on Redline MTL as compared to just the MT? Also if anyone else runs these fluids please post up.
Thanks again.
Thanks again.
MT-90 shouldn't be used for the differential.
Gl-5 For the differential,
GL-4 For the transmission.
MT90 is GL-4, for the transmission.
Just get anything that's around 75W-90 GL5.
Nissan recommends 75W-90 anyways.
it depends mostly on the weather in your area. since it's turning to winter, depending where you are, you don't want too thick of a viscousity in the gear oil.
here in so cali, the temperation never goes below 55degrees in most areas, so it's ok to keep MT-90 and use 75W-90 for differential.
s14 gtst
Jul 23, 2005 05:36 AM
