r33 rb25det spark plugs??? rb20det tranny gear box oil change???
Old Jul 22, 2005 | 10:22 AM
s14 gtst's Avatar
I have a r33 rb25det and I'm about to change my spark plugs but i am not sure what kind of spark plugs to use. i called mckinney motorsports and they said that any 300zx tt spark plug would work and that they come pre-gapped. but i read on a couple forums that the rb25det spark plugs should be gapped to about .8 and when i went to advanced auto parts to pick up some 300zx plugs they were pre-gapped at .4. i'm not really sure what to do. any suggestions? I am also planning on changing the tranny fluid on a rb20det and i was wondering if anyone knew what kind of tranny fluid to use, how much, and how to do it. Please reply. thanks
Old Jul 23, 2005 | 01:47 AM
iroc07's Avatar
easy, put them in with the factory gap and see if it works out, if you are having ignition troubles then you can adjust it from there, or call McKinney and have them double check. I have always used the factory gap and it has worked out fine.
Old Jul 23, 2005 | 05:36 AM
jonpowell's Avatar
.8MM on NGK V-Power plugs has worked best in my experience.
I like Redline heavy shockproof oil for the trans! Expensive, but it protects those delicate syncros.
don
Feb 18, 2011 11:15 AM
Mattyg2
Dec 20, 2004 02:58 PM
cticknor666
Oct 22, 2004 03:24 AM
Craig577
May 23, 2004 08:48 AM
drifterswanted
Dec 13, 2003 11:17 AM
