grinding in reverse
Old Jul 28, 2006 | 11:26 AM
phoenixangel_z's Avatar
Angry grinding in reverse
Hi there, i'm new to the forums, and an old Toyota fan who just moved over to my very first Nissan. Its a 95 240sx se, and i'm currently trying to get it to run smoothly (it sat for a year)
Replaced fluids, new brake pads, new batt, and the tires were still good. The problem i'm having is that when I try to put it into reverse, there is a bad grinding problem. the previous owner stated that he put a new clutch in before he left for Portugal, and i'm thinking its that, and hoping its not the synchros. any ideas?
Z
Old Jul 28, 2006 | 03:52 PM
prolly synchros, my sr did it before and after clutch install...still does most of the time..
Old Aug 10, 2006 | 04:49 AM
miked808's Avatar
Could be the Fluid in the Tranny. Make sure you fill it with GL-4 Type fluid. My Personal favorite is 1 qt. BG Synchromesh for cold trans. problems, 1 qt. Motul for hot trans. problems, and Top off with Redline MTL. Smooth as Butter.
Old Aug 11, 2006 | 02:00 PM
hicashatchback's Avatar
my car grinds 1st and reverse when moving, have to be close to a dead stop to put it in 1st and same with reverse.
Old Aug 11, 2006 | 02:20 PM
KAMAKAZI 13's Avatar
i have the same problem. my friend told me that it most likely has something to do with the driveshaft driveshaft.
Old Aug 12, 2006 | 03:03 PM
ArticDragon's Avatar
Change fluid to Redline MT-90 fluid. It works great.
Old Aug 16, 2006 | 07:44 PM
LA_phantom_240's Avatar
redline and royal purple are some of the best in the business...
james_s14
Jan 24, 2005 07:50 PM
fast240
May 7, 2004 08:50 PM
epoxy
Jan 30, 2004 12:12 AM
ryan15
Jan 28, 2004 10:59 AM
Tex
Dec 13, 2003 09:55 AM
