grinding noise when turning??
Old Jan 23, 2004 | 09:32 PM
ryan15's Avatar
when I back up kind fast or turn in like a parking lot it makes kind a grinding noise someone please help me out it been happening since I got the car, I need to know so I will get lucky at the junkyards tommorow.
Ryan
ryan15's Avatar
O yea I am also talking about when I back up, im turning also.
Ryan
Old Jan 24, 2004 | 09:30 AM
chriswgsx's Avatar
im sure this ISN'T the problem, but remember that reverse is a NON_SYNCHRO gear, so it will be louder and notchier. That shouldn't be it. You should check to see if it is coming from front or rear. that would help to narrow it down' if it is while turning it could be either an axle issue or differential issue. turn the radio off roll down the windows and try to isolate the problem. look under the car for leaks etc...
Old Jan 26, 2004 | 09:45 AM
kramsuey2268's Avatar
when i first got my car it would grind in reverse but only when going slow. From the sound of it, i thought it was the axle. But it ended up just being a worn out inner brake pad
Old Jan 27, 2004 | 08:34 AM
S13Nissan240SX's Avatar
Whats your wheel, tire, and suspension combo? Is it all stock? Do you get the grinding noise only when you turn the wheel a specific amount, or does it grind with the slightest turn. You might have something rubbing in the wheel well.
Good luck,
Matt
Old Jan 27, 2004 | 10:43 AM
crimsontide240's Avatar
yeah mine grinded only when I was going in reverse, and rather slow. I had a full brake job done (for other reasons) but I noticed that the sound and vibration never went away. So I have no idea right now as to what it would be.
Old Jan 27, 2004 | 02:24 PM
ryan15's Avatar
Well it doesnt seem like a huge problem, my om just gives me dirty looks when ever i turn at acertain angle like we are going to die, its is when I go slow and turn.Reverse and 1st it doesnt sound like the tranny or ne thing t do with that.
Ryan
Old Jan 28, 2004 | 10:59 AM
leemik's Avatar
hmmmm, so is this grinding noise coming from the tranny or the wheels? If it's the wheels it could be the wheel bearings..
--mike
wasaabi4784
Sep 4, 2006 05:39 PM
LA_phantom_240
Feb 9, 2006 01:30 PM
GodGiven315
Oct 22, 2005 01:55 PM
ixcocoyxi
Sep 12, 2003 11:42 AM
Monkey Boy
Sep 8, 2003 08:11 PM
