HELP< Clutch issues!!
Old Apr 30, 2004 | 11:40 PM
sooperspeed's Avatar
I need help. I just put a new clutch, master and slave cylinder. I bled the lines I have a firm pedal, but I can't get it into gear... I am tired and frustrated.
Does anyone have any ideas?
Old May 1, 2004 | 01:08 AM
Synchros(sp?)?
Old May 1, 2004 | 04:07 AM
but in every gear? one thing I didn't do was change the throwout bearing, could that have been it?
I am really bummed right now.
Old May 1, 2004 | 10:59 AM
ryan15's Avatar
I will tell you write now that can defenitley be it, your always suppose to change the throwout.
Ryan
Old May 1, 2004 | 05:31 PM
I just had a feeling that was it. I was in such a rush, now I have to change it in the rain.
Thanks for the help guys.
Old May 2, 2004 | 04:00 PM
Rouge S13's Avatar
did you try adjusting the clutch because if its not adjusted it wont go into gear...after you change the clutch its gonna have to be adjusted.
Old May 2, 2004 | 06:40 PM
what do you mean adjusting?
Old May 2, 2004 | 08:52 PM
Rouge S13's Avatar
when i changed my clutch it acted very similar to what you are describing and i just needed to adjust it. it is making the rod that goes from the clutch pedal to the clutch master cylinder longer or shorter by turning part of it. just look under your dash and youll see what im talking about.
Old May 3, 2004 | 06:39 AM
I just installed a new Master and Slave cylinder too. I will try adjusting it, but I have a feeling it might be the throw out bearing.
jt1583
Sep 17, 2005 09:32 AM
GREENs14
Mar 30, 2005 06:09 PM
crimsontide240
Oct 7, 2003 05:40 AM
EvoMperor
May 27, 2003 10:30 PM
