Help! I have some serious tranny questions.
I have a tranny out of a 91 and I am going to put it in my 95 OBDI. What kind of ECU do I need?? I have a 91 manual ecu and the pins are totally different. Do I need a 95 manual ECU?
you dont trick the ECU... you just take the NSS plug in the engine bay and connect the two wires together....
BUT...
you need a 95 tranny. the 91 tranny lacks the crank alignment sensor that the 95 tranny has. IF it runs, it will throw a CEL. sometimes theyll start without it, sometime they wont.
BUT...
yea your car is obdI
and you verify that by the amount of O2 sensors you have. you should only have 1 if its obdII. and in that case you should not have the crank sensor... you have to take into consideration the whole CA emissions 240 versions which were among the first to get obdII for its emissions upgrades.i have not worked with s14s much so i cant verify that....
OBD1 or 2 doesnt matter.
S14's have 2 O2 sensors.
S14's have crank alignment sensors on the tranny
BUT
early S14's dont care if that 2nd O2 is there or not
early S14's dont care if that CAS is there or not
hope you like driving with a CEL lit up
BUT
True but you can not just slap it in..the s14 bellhousing where the cas goes has a slight raise. S13 does not..so if you just slap the sensor in it will get eaten by flywheel.Find some sort of washer to raise it up slightly and clear plug end of sensor as well. I've done it once and also I've swapped the front bellhousings s14 onto s13 to have a cleaner install.
