Lsd
Also, if you have the rear end jacked up, just turn one of your tires in one direction. If the other tire spins the same way, you have LSD, if the other tire spins in the opposite direction, you don't have LSD.
Depends though. From what I know, if you have an S14, a 95' and up J30 dif. will bolt right up. With an S13, the output flanges for the axles is of a different bolt pattern. The S14 uses a 2 bolt pattern:
The pairs of bolts are actually closer together than this, its the best I could do. Just look at the two bolts on top in the little diagram, and you'll get the idea.
As for the S13 I'm not sure because I have a 95'. Sorry.
Heres a link though.
http://www.**********/Images/bulletin.htm
http://www.**********/links/installs/lsd2/index.htm
http://www.**********/links/installs/lsd/lsd.htm
check out both of those links
BRB
