LSD questions
LSD questions
i have a 96 se, 5 spd.
im looking at buying a vlsd from a 95 automatic. im wondering-
1. does it matter if it was from an automatic?
2. are lsd & vlsd interchangeable? do people just drop the v sometimes? or are they actually 2 different things, and is one preferable over the other?
3. i think ive gathered, from my research, that buying one from an s14 is the optimal choice, due to gear ratio & drive shaft configuration. is this correct? (i dont have any engine mods, so gear ratio should be proper, no?)
4. should i care much about mileage? i think this one has about 100k miles on it.
thank you!!!!
thank you!!!!
1. no
2. lsd is general reference - it can be viscous, clutch, or helical. "vlsd" specifically means "viscous limited slip diff"
3. s14 parts fit s14's.
4. not really just change the fluid because that's pretty much all you can do with a viscous.
1. no
thanks!
also thanks, but i also was asking which is typically preferable- could you tell me if you have an opinion on this? for different applications if need be? or for me personally(a little drifting but mostly roadracing)?
this is not one of your better attempts at being arrogant; you failed to answer the crux of the question. i asked what is best, not whether a square fits in a square-shaped hole. if you are going to be arrogant, it should be accompanied by good perception & thoroughness, lest you be made to look like the one being talked down to.
thats good news (i think?). thanks!
thanks!
3. go with one from an s14 is your best bet. The gear ratios on an s14 are the same as an s13 which is the same as a non turbo 300zx which is the same as a infinity j30. they are all the same vlsd like 95% sure and will work with little to no mods. i need to change out mine cause i have an open diff and thats what i pretty much gathered.
but why not get the one intended for your model if you can.. its a no brainer
CHANGE THE FLUID!!!
CHANGE THE FLUID!!!
a j30 fits in a s13 or s14... you just hace to change the diff covers. J30, 300zx, and Skyline's are all lsd's that will work in a 240. From what i heard differentials from aftermarket companies (clutch type?) are a little ruff, the vlsd is very smooth
If your doing mostly road racing and a little drifting the s14 VLSD sounds good for you, if you want to go with a different unit you could go with a 1.5 LSD made by an aftermarket company, that will also be helpful for road racing and occasional drifting.
I myself am more into the grip side of things and personally will be going with a helical LSD, dunno which one I'm using yet though.
and like they said, don't forget to change the fluid
BTW don't be ignorant. You don't know me so don't assume you know how I am when I am ignorant. I've been around this forum long enough to hear/read certain questions asked over and over with the same answers given over and over - and the whole thing could have been avoided if only the person asking the question put a little more effort in finding answers themselves instead of questioning someones "arrogance".
BTW good to see you put a real picture of what you were selling in the "For Sale" section instead of using the picture of my car that you took from my CarDomain page.
Originally posted by l2aine
apparently I under-estimated your intelligence twice:
I believe he is referring to this thead
ive never posted a for sale thread on here ********
(see s13_240 link above)
duh. enough already with your crying lol
CLOSED
Clarke240
Sep 25, 2007 03:38 PM
focalguy
39
Mar 9, 2004 09:07 PM
