no clutch pressure
Old Jul 13, 2006 | 04:08 PM
jeffwitda240's Avatar
no clutch pressure
Ok here is the deal my factory clutch wore out so i bought a stage 3 racing cluch bolted it to the fly wheel also i put in an nsk throwout dearing when i got it alll back together i went to bleed the clutch and never got a pedal i no im bleedin it right cause im a mechanic and so is my father but we cant fig out what the deal is does anyone have suggestions
Old Jul 14, 2006 | 01:07 AM
Is your master or slave cylinders bad? Are you bleeding it from the slave and the damper loop?
Old Jul 14, 2006 | 09:05 AM
no the slave and master cylinder are fine i even replaced the slave an still got nothing but i did notice that other bleeder and tried bleeding tht to is there some kind of way u gotta bleed both of these at the same time or in some kind of order to get all the air out thanks
Old Jul 14, 2006 | 09:41 AM
I believe you bleed the damper loop first and then the slave.
Old Jul 14, 2006 | 10:44 AM
re037's Avatar
i remember someone mentioning bleeding the damper with the front of the car raised. or you could just get rid of the damper
just make sure you bend the hardline slowly so you dont pinch it
Old Jul 14, 2006 | 02:54 PM
ok buddy imma try it and see wut happens il let u no how it goes
Old Jul 16, 2006 | 01:16 AM
ok here is the deal i gotta my car running it drives an shifts jus fine put my pedal is jus sloppy as hell an dont come up all the way i think there is a cable i gotts tighten up imms do it tomorrow an by the way i love how the stage 3 clutch grabs
JH240sx
Jul 18, 2006 09:27 PM
D Grade
Nov 29, 2005 10:00 AM
redtopS13
Jan 19, 2005 08:08 PM
jackyliem
Dec 30, 2004 04:24 PM
duckman240sx
Apr 6, 2004 07:00 PM
