Noise from BRAND NEW CLUTCH!arrrgggg
Old Sep 1, 2004 | 03:14 AM
Sizzzoooo's Avatar
We just put in my Blitz Single Active clutch w/ fly.
Design:
Flywheel-disc-slottled rotor/disc looking thing-pressure plate
I am concerned about the noise it makes. It sounds like the rotor or flywheel was rubbing/grinding-kinda like worn brake bads on brake rotors. It ONLY does makes the noise when the clutch pedal is put in. What I have sounds like rocks rubbing against metal. It does it all through the gears, even through conservative shifting. Here it happens when the clutch is engaged. No matter if I ease out on the clutch or not. It will do it if I just hold the pedal down as well. The rubbing progressively gets louder.
Is that normal? The only thing I can think of is the clutch disc on the flywheel since the surface of the flywheel was pretty rough. I'm assuming this is part of the break in cycle.
Phase2Motortrend says
"The 'chattering' noise that you hear when you step in the clutch pedal is normal. That's how it is with most single plate clutch kits like Blitz and Exedy. That is because the nature of the throw out bearing they used will vibrate and make that noise."
Does that make any sense?
Any help would be great!
Old Sep 1, 2004 | 10:58 AM
From what I have heard, it is normal. My buddies car makes the same noise(I'm 90% sure he has the blitzh single active clutch) and he has had for quite sometime now...no problems
Old Sep 1, 2004 | 12:49 PM
juztinvez's Avatar
sweet i want one now so my car will make another annoying noise when it is running correctly. i might give the exedy one a shot. My buddy said there is a spray for brake pads that might quiet it. should be easy to access since we never put that fork boot on. I'm workign on gettign you that speed sensor later today. if not i know where another is
Old Sep 22, 2004 | 08:52 PM
TWT00's Avatar
Yeah, I have a Apexi twin plate clutch and its loud as all get out at low RPM. I guess its just something you have to get used to.
Old Sep 22, 2004 | 11:38 PM
gladhatter's Avatar
Perfectly normal. I hate it. It sounds like a throw out bearing going bad but it is normal.
Old Sep 25, 2004 | 09:16 PM
Sizzzoooo's Avatar
sweet, feedback like this makes me feel better..lol
Chiefgmsr
Feb 1, 2006 12:49 AM
ehxtahcee
Nov 10, 2005 03:27 AM
Sick SX
Sep 25, 2005 12:52 AM
azn-racer
Nov 30, 2004 09:26 AM
s0ldats
Dec 22, 2002 11:21 AM
