Clutch fan noise
Old Jan 19, 2006 | 03:48 PM
Chiefgmsr's Avatar
Clutch fan noise
When my car warms up I start hearing a rattleling by the clutch fan. I started moving it around cuz I wanted to see if it was hitting the fan shroud which it is. I also noticed it can move a lil bit foward to back. Like its wobblely. How do I tighten it up to make it stiff again. Should be easy, just wanted opinions b4 I get in there.
Old Jan 19, 2006 | 03:57 PM
TireSmokeS13's Avatar
When i still had KA mine always did that, I just made some holes into the plastic, and ziptied it back..well you should get what im saying.
Old Jan 19, 2006 | 04:08 PM
Ron Smith's Avatar
If it is tight and still loose than the bearings are shot!
Old Jan 19, 2006 | 05:05 PM
Chiefgmsr's Avatar
What's needed? Just the bearings?
Old Jan 19, 2006 | 05:27 PM
KisorPerformanc's Avatar
na.... make sure it is just the fan clutch that is moving and not the whole waterpump pulley... if it is just the fan clutch then swing down to the local parts store and get a new one, easy to put on.... just take off the 4 nuts on the water pump pulley and then seperate the fan from the clutch.... reverse procedure for install of new one.....
if the whole pulley and everything is moving, then the waterpump bearings are shot... i.e. new water pump
thanks,
Brad
Kisor Performance
(513)891-2295
Old Jan 19, 2006 | 10:17 PM
revolutionz_s13's Avatar
do it the right way an take that ****ty fan outta there...put in electric ones for like $60 or so....makes a big difference.
Old Jan 20, 2006 | 06:23 AM
Ron Smith's Avatar
Agree. Clutch fans suck. Electric slim is the way to go. Much more efficient. I have known people in Japan that had a switch to turn their fan on. You can control the temp. Make sure you have a good temp guage. Cooler engine, longer life.
Old Jan 20, 2006 | 04:58 PM
Chiefgmsr's Avatar
I'm doing my SR swar this summer and will prob do elec fan.
Old Jan 26, 2006 | 08:38 AM
im4streetracing's Avatar
here's an idea for now. for a quick temporary fix, there is an electric fan just in front of you clutch fan. you can pull out your clutch fan, and splice that electric fan into the ignition wire in the harness just in front of the valve cover. dont want to sieze that clutch fan and don't want it to break off and smash into your radiator. just run positive into igniton wire, and neg to the neg. terminal on your battery. believe it or not, i dont' care what anybody says, that fan it big enough to keep your car kool. my friend did it on his, and mine is temporairly hooked up that way.. just another option for you to use
Old Jan 26, 2006 | 08:41 AM
it will also make your car run a lot quieter under the hood. that clutch fan is wicked loud. I HATE it
Old Jan 26, 2006 | 08:57 PM
Chiefgmsr's Avatar
lol thx. but i love that blower sound.
Old Feb 1, 2006 | 12:49 AM
Chiefgmsr's Avatar
Well yea it was my fan clutch. It went bad so I replaced it. Thanks for everyones input.
Scuderia
Oct 21, 2007 03:05 PM
bucket240
Jul 31, 2007 11:06 AM
iNmotioN
Apr 25, 2006 10:48 AM
sleighty
Mar 31, 2004 07:46 PM
ricks89240
Sep 25, 2003 07:35 AM
