Opinions on Aluminum Driveshaft
Old Sep 1, 2005 | 12:57 AM
Watashi wa Sake's Avatar
I was wondering if anyone has or knows someone with one and what they think about it. I know it would reducing rotating mass and help with throttle responce and would be in theory be good but I want to know about real life use of this.
Do you think it would be benefitial to get this in the long run, or stick with the stock 2 piece steel driveshaft? The aluminum driveshaft is rated around 800hp and is 1 piece, so it sounds like it is a little more solid than the stock one as well as being lighter weight.
http://www.store.yahoo.com/phase2mot...0aldr8924.html
Just trying to find peoples opinions about this.
Thanks for any information any of you have about this.
Old Sep 1, 2005 | 01:03 AM
Waynehead05's Avatar
what do you plan to do with your car? if you aren't going into motorsports it would be a waste of money.
Old Sep 1, 2005 | 03:04 PM
Yeah right now my car is for Drifting and Autocross as well as a daily driver, I have friends who go to the drag strip so I go with them every once in awhile, thats really not my thing though i like to challenge myself as a driver not go in a straight line as fast as I can go. But hey to each there own.
I am more curious about it right now than actually considering buying it. I might buy it if I feel i feel it would be a good investment in the long run. Was just wondering if people thought it would be an ok replacment for the stock driveshaft durability wise, and if people thought the cost/performance was worth it too. It nothing I am planning on running out and buying right away anyways like I said I was more curious about it.
Old Sep 3, 2005 | 11:11 PM
it'll help you get your revs up quicker... it may give you a little less tq loss too. (better dyno number)
Old Sep 4, 2005 | 08:13 AM
CowboyTurbo's Avatar
I dunno, my mechanic mentioned the alum. d-shaft to me too. He said that it actually doesn't cost that much. Can't remember the figure he quoted me though...
Old Sep 6, 2005 | 12:06 AM
a new stock one vs. an aluminum one in terms of price ain't much different... in terms of weight it is way different.
Old Sep 7, 2005 | 09:09 AM
BigVinnie's Avatar
Aluminum drive shafts are great. I all ready have an aluminum fly wheel. The driveshafts are stronger than I thought and they don't flex, and stretch. Supposedly they only weigh 11lb.s, which is lighter than the 27lb.s that originally come from the 240sx drive shaft. It will make wire tires skirt upto 3rd gear for every upshift you make. Dropping the rotational mass, from the degredated drive train will also add a HP or 2 to the wheels....
Old Sep 7, 2005 | 02:21 PM
miked808's Avatar
It's not as impressive by itself on the Butt Dyno, But it is a Great Supporting Mod! If you can get a Deal do it.
Old Sep 7, 2005 | 06:50 PM
I've never heard of anybody swapping out a driveshaft when doing an SR swap. I'm assuming that driveshafts of the same dimension can be used on either the KA or the SR. Is this correct?
Old Sep 8, 2005 | 01:02 PM
miked808's Avatar
Yes.
Old Sep 8, 2005 | 06:51 PM
2fast4y0u's Avatar
yes in a sense of manual trans to manual trans.
i went from auto to manual so i had to buy a manual drive shaft to complete the swap
Old Sep 22, 2005 | 09:56 AM
akinaspeedstar1's Avatar
no offense but how many times have you been to the strip? It takes much talent to drag...go to a local battle of imports or something like that and you will see 80% bad launches bad shifting almost hitting walls (almost hittin walls while burning out LOL). ETC ... just dont say its not hard to go in a strait line it may not be challenge to do but a challenge to do correctly...
Old Sep 27, 2005 | 02:50 AM
ArticDragon's Avatar
I believe phase2 sells one piece aluminum driveshafts.
Old Sep 29, 2005 | 12:31 AM
it's not rocket science launching a daily driver 240sx
As for the aluminum driveshaft, I suppose it would be a good upgrade later down the line... like way down the line after most of the other stuff on the car has been addressed already... a stockish 240sx wouldn't really need an aluminum driveshaft (yet) as opposed to spending that money on hter things like lightweight flywheel, motor/tranny mounts, etc.
Old Sep 29, 2005 | 07:31 AM
twofourtyesex's Avatar
Banned
raine is correct, aluminum driveshaft is not really NEEDED unless theres other mods already done to the motor. lightweight flywheel/driveshaft combination is basically gonna make your car's revs rise AND fall real quick. ...BUT remember, the less rotating mass, the more precise your "clutch skills" have to be. gripping point is gonna come up real quick. anyways. good luck.
