Reverse Lights Wires? (Fuse Box)
ok here ya go... this shoudl take care of it
wou will need wire cutter, wire strippers, electrical tape, soldering iron and solder.
off of the reverse light switch there should be two wire. solid green with pink dots and green with white stripe and pink dots
they run up and go into the main harness for the car. just to the left of the alternator. open that harness up and grab the two green wires out.
now your fuse box should have a bunch of plugs with nothing in it just hang on.
there should be a grey plug with 7 wires in it. in that plug there is a solid red wire and a solid green wire. pull back the wire cover enough to get access to the wire it self.
ok, the green wire with the white stripe is going to get connected to the solid red wire. and the solid green goes to solid green. solder your wires together and tape them up....
*****make sure you do not have the tranny in reverse when you hook these wires up...
let me know if you have any other questions
Jay
Jay
CValle86
Sep 26, 2005 06:04 PM
darook
Aug 13, 2005 05:42 PM
