A/T will not upshift over 5000 RPMs
Old Jan 22, 2009 | 02:39 PM
bf02's Avatar
I just bought a 1989 240sx with the 2.4-litre SOHC KA24E engine and Automatic transmission. While driving the car if the rpms go over 5000 then it will not upshift. Has anybody heard of this happening and if so how can I fix it?
Old Jan 22, 2009 | 04:42 PM
Evans1109's Avatar
Did you happen to check out your other posts on nissan.forums and nico? If not you have a good reply from a member from nico, here is his post
I would try changing the speedo sensor. What happens is the when you step on the gas hard the throttle pressure will overcome the governer pressure(relative to speed) and delay the shift then once the speed gets to a certain point the governer pressure will be more then throttle and shift you into second.
Run the codes, a code might be stored without the check engine light being on because that only turns on when the code affects emissions.
Check it out and post back.
Old Jan 22, 2009 | 08:21 PM
bf02's Avatar
Thank you for the heads up. I checked out the post and replied.
1990sx
Sep 20, 2005 06:30 PM
jmack240
Apr 29, 2004 08:00 AM
oSOlo240
Feb 17, 2004 08:03 PM
Major Mayhem
Jun 17, 2003 12:03 AM
Sinfestboy
Dec 18, 2002 05:19 PM
