tiptronic 6 speed for S15 SR20DET 240sx
Hey i have a 240sx 1993 i put in a S15 SR20DET Spec-R Silvia engine with turbo.
it is a 6 speed manual transmission.
my question is does anyone know where i can get a custom or premade Tiptronic (autostick) transmission for my car with the engine im using. preferrably stick shift and not push button shift.
6 speed tho.
thanx in advance
6 speed tho.
thanx in advance
Originally posted by uofa240
Why would you want Tiptronic? To take all the fun out of driving?
but to reiterate; can i directly swap in this majestic sr20det with a 6 speed manual?
a 6 speed would be godly.
Originally posted by audiophile
can i swap it into my s13 directly?
Yeah it's really easy, just more expensive. If you use the 6-speed, whether it's w/ a S15, S14, or S13 engine, you need to get the S15 differential as well beacause the speed sensor for the S15 is mounted on the diff.
you will just have to do with out a Speedo.
www.dennysdriveshaft.com
builds custom driveshafts everyday. not only will you have a warrenty on breakage or twisting, you will free-up HP
so it will bolt in like what...but keeping your speedo will take some custom know-how....feel me?
have fun with it. S15 swap is far from easy. you need the driveshaft and diff. the wiring is more complicated, and the diff will not bolt up. youd have to make custom output shafts. the 6-speed is NOT godly at all. its commonly swapped out for a 5-speed. and AFAIK you cant use the 6-speed with S13 or S14 SRs.
and why would you want tiptronic? thats super gay.
erothem
Sep 8, 2006 09:02 AM
cleanblk240sx
Oct 8, 2005 03:33 PM
s14.5boy
Sep 26, 2004 08:01 PM
