AT - won't shift to D / key get stuck / won't start
Old Jan 9, 2006 | 07:23 PM
redline88's Avatar
Hello everyone...I am new to this forum so please bear with me.
I have a 95 240 Auto with 150K and it has been acting up on me. I wonder if anyone has had these problems before or have any ideas on how to fix it.
1) At times I have to play with the shifter to start the car. It takes jiggling the shifter + brake pedal. The battery is 1 wk old, the alternator is month old.... maybe it's related to the second issue
2) There are times that I can't shift it out of Park no matter how I play with the shift + brake pedal whether the engine is on or not. I have found out as well that I really have to push the shifter all the way to Park (till I hear a click) in order to take the key out.
Any information would really help...
Thank you so much.
Old Jan 10, 2006 | 03:05 AM
Levi SPL S14's Avatar
the "click" is a lock type mechanism a safety thing.
Its connected to a few other things. Try and see if its loose and what not.
Old Jan 10, 2006 | 05:33 AM
Roastem's Avatar
maybe some adjustments on the realease mechanisms??????
Old Jan 10, 2006 | 12:37 PM
redline88's Avatar
thanks for the input.. i'll give it a shot this weekend.... will let you know =)
Old Jan 10, 2006 | 03:07 PM
Joel SX's Avatar
May be the litle actuator that locks it in place. Its located underneath the plastic covering of the shift ****. Inexpensive and quick. Might be the brake sensor that is not sending the signal to the trans ECU? try testing the actuator that locks it, try testing the plug for voltage see if there's a signal to it. My worst case scenario would be the "Inhibitor switch" but that can't be.
Old Jan 15, 2006 | 12:33 AM
Razo-E's Avatar
to take the key out, you gotta push the shift lever all the way forward until you hear a click, otherwise it wont release your key...
also, i dont know about S14 trannies, but on my S13, i have a little red **** that you can push, and it'll release the locking mechanism..
Old Jan 17, 2006 | 09:31 AM
redline88's Avatar
sorry guys, i did not get a chance to try out your suggestions this weekend...
weather has been brutal here in NJ... at least the car is covered in my driveway
waiting for a warmer weather =)
but will keep you posted. thanks again.
Jeff Handy
Jan 9, 2007 03:20 PM
240sd
May 5, 2006 12:24 PM
Topless
Apr 6, 2005 02:09 PM
tdogg1286
Jul 2, 2004 07:15 PM
jbird240sx
Dec 8, 2003 08:01 PM
