'89 with a SR20DET
Old Oct 24, 2005 | 09:22 PM
tenkhead's Avatar
Exclamation SR20 Help
Ok, so here is the problem, or situation rather.
I have a 89 240 hatchback. I just put in a SR20DET with tranny, ECU, a new comp. clutch, new GReddy intercooler and blowoff valve.
Whenever I start it up, it hums just fine, however once I drive around for a bit it seems to try and stall out whenever i slow down for a red light or a stop sign the RPM's drop too low and it trys to stall out.
I've been asking around and the general idea is that my blow off valve needs to be tweaked up a bit. Also, it seems to me that perhaps my blow off valve is pushing out too much air messing up my Mass Airflow Sensor.
Any advice on this? Or perhaps parts to replace? Help!
Old Oct 24, 2005 | 11:49 PM
Helghast's Avatar
wrong section.
Try re-circulating your BOV..see what happens.
Old Oct 25, 2005 | 06:32 AM
Have you done the basics like CAS angle? BTW moved to swap section (whatever it's called)
Old Oct 25, 2005 | 09:44 AM
nsn240's Avatar
why double post??
s14Drifter
May 25, 2009 12:35 PM
tonyfizzle
Oct 10, 2005 06:14 PM
LK0
Apr 14, 2004 06:18 AM
