after frount clip??????
cool, thanks for the tips. if it was you would you do the swap your self or have a shop do it and if you would rather have a shop do it do you know of a good place as close to wisconsin as posible,how i can get a hold of them, and maybe prices???
Since there is so much info out there on the SR, i would do it myself. It isnt hard at all, there is a guide for the wiring. The wiring is the hardest things, but since there is a guide and it isnt difficult at all, its all good.
Originally posted by Nismo241
I don;t think a spark plug can be considered a bolt on
Originally posted by NightXCZ77
I consider Iridium plugs a bolt on compared to the stock plugs that are thrown in the engines and burn out every 2 weeks lol. Not only do Iridiums hold up a lot longer, but they provide a power increase as well.
someone will probably say this if i don't so i will pop the cherry on this thread. a lot of people have trouble with the throttle cable assembly on the sr (because of right hand drive in japan) so use the one from the ka. if i think of anything else that isn't really all that necessary to add i will. good luck!!!
Luv2Surf247
Feb 24, 2002 11:24 AM
poisonfist
Feb 10, 2002 04:07 PM
