CA18DET question, interchangeable parts?
Old Feb 3, 2005 | 09:02 PM
gazelle's Avatar
Arrow CA18DET question, interchangeable parts?
I am looking at getting ca18 engine + tranny from zerolift, can i use ecu from 200sx? i know 99% of parts are interchangeable, also wiring harness or engine tranny mounts? can i not just go to nissan dealer or junkyard and get these? thanks!
Old Feb 4, 2005 | 08:48 AM
Skiboard06's Avatar
the engine and tranny mounts will most likely be attached to the engine and if they arent you can use your old engine and tranny mounts they r the same thing. You will need the ca18det ecu and wiring harness (uncut) ask catharis for more info
Old Feb 4, 2005 | 01:05 PM
gazelle's Avatar
Well, all knowing Catharsis, have any advice?
I also know when i get the engine and replace a bunch of parts simply cause of its ol age i can just get them at nissan, figures the hard ones ill need to be tracked down ...
Old Feb 7, 2005 | 10:57 PM
zilvia.net has the whole print out of what u need as far as parts go.
u just ask for the part as if u had a 88-89 Pulsar NX SE
im allso doing that swap but the problem i have is the motor comes with a auto tranny. i was told i had to switch the bellhousing from the ca to the ka tranny. but being that its auto that will not work right?
Old Feb 8, 2005 | 10:11 AM
jonpowell's Avatar
If you want your turbo engine to run on NA fuel maps, use the 200SX computer.
b2stud
Jan 3, 2004 04:34 PM
camrytrd93
Dec 1, 2003 10:22 PM
redwinger
Oct 16, 2003 01:01 PM
adavib
Sep 1, 2003 06:49 PM
Nzo
Jul 18, 2002 03:53 PM
