can't get motor on mounts help!
i havent heard of anybody running into this problem.When i went to put the SR back in i cant get the motor mounts to line up in both bracket holes on the motor i was wondering if anyone has heard this before and can help me?
Originally posted by JDMxDrift
Try swapping them around. left to right-right to left.
Don't waste your time with that ^^. Is the tranny attached to the motor? Need more details. Just work with it, it'll go in, make sure everything is clearing, make sure the motor is level, use some pursuasion if need be.
Originally posted by Amp
yea tranny was attached everying was clearing worked with it for about 10 hours if i get one side on a little bit the other is still about an inch away
Originally posted by Slip&sliden 240
Try geting one in and nut it, and then using a spare strap hook it around the stud on the mount and pull it into place
im going to try that this weekend thanks for the replys well see how it goes.
Do you have the engine mounts on the engine or still mounted on the car? It is a hell of a lot easier if you put them on the engine first, I got mine lined up by myself rather easily when they were on the engine. But when we swapped an engine on my friends car we left them on the car and it took about 40 mins to a hr to get it lined up with four guys helping. Just a thought.
